Will this aftermarket cpu cooler fit in this case?
Last response: in Components
Power supply Master
CPUs Authority
Thanks to R4 being particularly wider than other cases helps to accommodate big CPU coolers, pictured is Noctua’s NH-U12P which is 158mm in height. As you can see there is lots of clearance for this cooler to reside within R4. There is sufficient space for even bigger coolers such as Noctua NH-D14, Thermalright Silver Arrow and Alpenfohn K2 which are all 160mm in height.
Uploaded with ImageShack.us
Ask the community
