Help with PC Case!!
Hi,
I'm building a pc and I can't decide on a case. I have considered the Corsair 400r but i think it is too big for a m-atx motherboard.
It would be a great pleasure if someone could recommend a case. I'll be using a m-atx form factor motherboard with Antec 620 liquid cooler.
The case must also have 2 usb3.0 and able to fit in MSI GTX660ti PE. Budget would be $120. The looks of the case does not matter as it will be under a table in my room, so people won't see it that much.
Thanks in advance
4 answers Last reply
More about help case
  1. Rosewill CHALLENGER-U3 Black Gaming ATX Mid Tower Computer Case ,comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, front mounted dual USB 3.0 $60.00
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811147060
  2. I initially wanted to get that case before the 400r but it was unavailable in my country currently as they are getting ready for the new rosewill cases. :cry:
  3. and what is your country?
  4. Singapore!
Power Supplies Cases Motherboards Components Product
