I've just finished a new build with the Sapphire Radeon HD 7950, and have had some display issues that I'm not too sure how to solve.
I have two displays: One is a Dell, and the other is a Vizio HDTV. The HDMI and DVI both work for the Dell monitor, but no matter which type of connection I used on the Vizio HDTV, it has bad picture. The picture looks odd colored, and almost looks pixelated.
I've messed around with different resolutions, and pretty much every display setting in Catalyst, but nothing fixes it.
My last GPU (EVGA 8800 GTS) ran both monitors perfectly, so I would assume a 7950 could do the same.
Would any of you possibly have any ideas to what's causing this issue?
Thanks in advance
Thanks in advance
