I had windows 2000 set up and in tv-out display everything was black and white on the television. I could not find a single reference to it in troubleshooting. Can anyone help me? thanks
Turn off both and re plug the RCA addapter, then turn them back on. Also, if this doesn't work, try changing the settings to NTSC Output, you may be using PAL, the Europe standard, and this will cause your TV to be Black and white as well.
Its been awhile since I used TV out. Go to the drivers, click on the tab that says <b>Displays</b>, you should see two items <b>Monitor and TV</b>, click on the <b>TV</b> button and adjust your settings including color.
