Hi, just finished building my computer, this is not my first, I know how to manipulate all the components and I'm pretty sure I did not forget a cable, or break something. All components are working fine the GPU, HSF, motherboard, power supply, fans, led, front panel. Thought I did not check the PSU because i do not own a digital multimeter and i can't really borrow one. I also made couples of the steps in this help guide :
http://www.tomshardware.com/forum/261145-31-perform-steps-posting-post-boot-video-problems
My build is :
Antec Three Hundred ATX
ASUS P8Z68-V PRO/GEN3 LGA 1155 Intel Z68
EVGA GEFORCE GTX 670 FTW
CORSAIR CX600 (600W)
Intel Core i7-2600K 3.4GHz (LGA 1155 95W) with Intel HD Graphics 3000
G.SKILL Ripjaws Z Series 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
Seagate Momentus XT 750GB
I really need help ! Maybe its a problem with my components choice? Maybe a did break a piece? I have some doubt with my Power supply, maybe it down not have enough voltage, or maybe my RAM is not compatible because on the box it says "made for LGA 2011. I just don't know ...
HELP!!!!!!!
My build is :
HELP!!!!!!!
