Case fan cable
So I got these case fans http://www.newegg.com/Product/Product.aspx?Item=N82E16835103022&name=Case-Fans
and I have this psu http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095&name=Power-Supplies
The cable from the case fan is too short to reach the motherboard. I am wanting to buy a 4 pin molex cable to 3 pin fan adapter, or an extention to hook the fan up to the motherboard. I dont know what to buy.
2 answers Last reply
More about case cable
  1. If you buy a 3-pin to molex, the fans will be running at 100% all the time. If you buy an extension, they'll be controllable. Personally, I have my fans hooked to a fan controller, which then gets its power from two molex connectors.
Power Supplies Cases Fan Cable Motherboards Components Product
