Hi!
I've recently updated my hardware at home and have just tried connecting one of my graphic cards to my new TV but I'm not quite satisfied with the results.
Currently I'm duplicating the displays and when viewing on my computer display the videos and games run smooth without problems but on the TV I get the feeling that it's a bit out of sync and I experience the movement slows down and catches up in short intervals (I'm sorry for not beeing able to describe it better).
Resolution: 1920x1080
Refresh rate: 60hz
HDMI-HDMI cable: 10m (~33 feet)
Computer specs
*Graphic cards: 2x Asus GeForce ENGTX560 DCII TOP/2DI/1GD5 1GB
*Motherboard: Asus P8Z68-V Pro/GEN3
*Power supply: OCZ ZX Series 850W
*RAM: 16GB - Corsair XMS3 Vengeance DDR3 PC15000/1866MHz CL9 2x4GB
*Processor: Intel Core i5 2500K 3,3GHz Socket 1155 Box
*HDD: Corsair Force GT Series 120GB
*HDD: Samsung EcoGreen F2 HD103SI 32MB 2TB
*CPU fan: Zalman CNPS10X Performa
I've tried setting the TV as my primary display and ran it as a single display but the result was the same (tested from both cards). I've also tried lowering the refresh rate between 50-60hz but with no good results.
Have I missed something simple or might it be the HDMI cable itself?
I've read alot of threads stating that longer cables can produce bad results but I've also been reading an equal amount of threads that it's just talk. As long as the 1s and 0s reach the device the result will be the same. So instead of buying an expensive Supra/Monster cable I bought an cable from Exibel which was reasonably priced in between the most expensive and the cheapest. Since the GTX 560 has a mini HDMI I'm using the adapter that came with the cards, if that might be an issue.
I'm really not up to date regarding how this works and I hope someone with more experience can help.
A big thanks in advance!
Best reguards,
Kenzai
Refresh rate: 60hz
Computer specs
Best reguards,
Kenzai
