Approximate Purchase Date: ASAP
Budget Range: 1k. I want to keep it at or under 1k, as I have a 1k budget but would like to be able to fit some new games into that budget...
System Usage from Most to Least Important: Gaming, Movies, Graphic Design, internet browsing
Parts Not Required: Keyboard, Mouse, Monitor, Speakers
Preferred Website(s) for Parts: newegg.com (preferred), ncix.com
Parts Preferences: Intel CPU
Overclocking: Maybe
SLI: Maybe (I have a
Monitor Resolution: 1440x900
Additional Comments: I want to build a rig that will keep me gaming nicely for the next few years. I have a 1k budget and have assembled a preliminary parts list for that budget but I want some help trying to figure out how to take the specs and parts that I have and figuring out ways to make the build less expensive so that I can spend some of my 1k budget on games. If that doesn't seem reasonable for my objective, please let me know, I am open to any and all advice and constructive criticism.
Parts SO far:
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
HDD:Western Digital RE4 WD5003ABYX 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136697
VideoEVGA 012-P3-1570-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593
owned video card (potential sli):
8800 GT (not sure who manufactured, don't plan on sli soon)
PSU: SeaSonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
Memory: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
MOBO: ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
CPU: Intel Core i5-3550 Ivy Bridge 3.3GHz (3.7GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 2500 BX80637I53550
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116505
Overclocking: Maybe
Parts SO far:
