Hello all, im building my first computer and before i hit go i want to make sure i didnt make any silly mistakes.
If you see anything that isnt compatible or would be better for less or around the same price please let me know!
(i really dont want to go much over 1500)
Case: Cooler Master Storm Enforcer USB 3.0 Mid Tower $85
http://www.amazon.com/Cooler-Master-Enforcer-Interior-SGC-1000-KWN1/dp/B004WK3KKQ/ref=sr_1_2?s=electronics&ie=UTF8&qid=1336880925&sr=1-2
CPU:Intel Core i7-2600K Processor $300
http://www.amazon.com/Intel-BX80623I72600K-Core-i7-2600K-Processor/dp/B004EBUXSA
Motherboard: ASUS LGA 1155 - Z68 P8Z68-V PRO/GEN3 $206
http://www.amazon.com/ASUS-LGA-1155-Motherboards-P8Z68-V/dp/B005UDITPK/ref=pd_sim_e_4
RAM:
RAM: Corsair Vengeance Blue 16 GB DDR3 $95
http://www.amazon.com/gp/product/B004RFBIUU/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B004EBUXSA&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0D7274D6V15M5KX774TQ
GPU: GTX670 $400
SSD:Crucial 256 GB m4 $180
http://www.amazon.com/Crucial-2-5-Inch-Solid-State-CT256M4SSD2/dp/B004W2JL2A/ref=sr_1_2?s=electronics&ie=UTF8&qid=1336881276&sr=1-2
HDD: SAMSUNG Spinpoint F3 1T $80
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
PSU: Cooler master Power Supply 240-Pin 1200 Power Supply $164
http://www.amazon.com/Cooler-master-Supply-240-Pin-RSA00-AMBAJ3-US/dp/B002RWJGCM/ref=sr_1_8?s=electronics&ie=UTF8&qid=1336881084&sr=1-8
OS: Already have it
TOTAL: 1510
For the most part i picked out all the parts in the "people who bought this item also bought" section, so my main concern is that it is all compatible.
However, im not sure im getting the best bang for buck either. I dont want to spend more, but if im missing something thats a significant upgrade please let me know!
Thank you.
RAM:
GPU: GTX670 $400
OS: Already have it
TOTAL: 1510
Thank you.
