Could you guys please check the parts i want to buy?
Last response: in Systems
- Could someone just check my parts before I buy them please ? - Forum
- <b>Hey Guys...could you please check my config for my build & give me some suggestions or advice?</b> - Forum
- Could you guys take a look at my build before I buy the parts? - Forum
- Could Some Computer Guru Please Check the compatibility Of These Parts - Forum
- Build ready. Could you guys please check for anything wrong? - Forum
- Solvedi want to buy a gc.. confused between gainward nvidia geforce gtx650 and hd 7770... guys please help me.. Forum
- SolvedWant to make sure my first build will work before I buy parts. PLEASE HELP! Forum
- SolvedCould you guys check these two builds ? Forum
- So I wanted to know if my pc would work. I am new to pc buildings and if I missed any parts could you please tell me. Forum
- First Time Builder, Could you please check my current part choices? Forum
- SolvedHey guys I about to order my PC parts online tonight and I wanna check if everything works great together before I order it. Forum
- SolvedBefore I buy could you look over my first build parts? Forum
- SolvedGuys am from india i want to build a decent gaming pc.i have choosen some parts like cpu,gpu etc for it.plz help me are those Forum
- Budget Build Just Want Checking please or parts recomendations. Forum
- Solved(Build check).. Hey guys thinking to get this build? Please advise Forum
- SolvedHello, its my first time building a pc, could you guys please tell me if this build is good? And what settings would I be able Forum
- Please check my parts list before I buy this Friday. Forum
- Hey guys I want to expand my mac pro 2009 it's running 250 gig and I own a external terrible drive is it possible I could crac Forum
- SolvedIn what order should I buy the rest of my parts and what other advice would you guys give me ? Forum
- SolvedNot sure if i should buy these parts, because of any problems that could happen and any improvements under the $1500 budget Forum
- More resources
