Hi, I'm thinking of building a desktop for BF3, and was wondering if these parts are compatible together, and will perform well. If you have any suggestions please feel free to state them, my budget is $820 at maximum. My resolution is 1920x1080
Chassis:COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
Mobo:GIGABYTE GA-880GM-USB3 AM3+ AMD 880G HDMI USB 3.0 Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128440
GPUowerColor AX7850 2GBD5-DH Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131473
CPU:AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
HDD:Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
RAM:CORSAIR Vengeance 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ4GX3M1A1600C9B
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145346
PSU:CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
OPTICAL DRIVE:SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031
CPU COOLER:Rosewill RCX-Z100 One ball bearing for over 45000/hrs life CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835200017
And of course, Windows 7.
