Hi guys!
I just attempted my first motherboard/CPU upgrade, but I've run into a problem.
First, here's my setup:
Intel i5 3570K processor w/ stock cooler
Gigabyte Z77X-UD-3H motherboard
8Gb DDR3-1600 RAM
HIS Radeon 7970 Video card
Cooler Master 850W PSU
I installed everything, plugged everything in, and when I went to turn it on, nothing happened. The light for the mobo mounted power button turned on, but thats it. No fans, no beeps.
I went through the troubleshooting guide, and found that after I took the video card out, the system powered up no problem. I put the video card in again, no power.
Is there a solution for this? Is it a bad PCIe slot? Do I need to update the BIOS?
Any help you can give would be much appreciated!
8Gb DDR3-1600 RAM
