Quote:
?, No clue where you pulled that rather shocking theory from, but you are wrong...
I pulled it from nVidia site which was clearly indicated by the link. Personally, I'm never anxious to file a warranty claim by submitting my sales receipt which also has a 750 watt PSU on it while the manufacturer's web site clearly states that for two 295's it should be no less than 969 watts.
The site says 680 watts for
one GTX 295...... an argument that the 2nd one, it only increases the recommended minimum size by 70 watts would not be rec'd well. You don't put a 700 watt load on a 750 watt PSU because it's not just about power draw on day 1 ..... it' about sizing for capacitor aging, and sizing for enough headroom to allow the unit to produce stable, ripple free power under all anticipated loads.
The OP titled this thread "295 gtx possibly SLI Problem " so I am assuming he has two GTX 295's in SLI. The 295's max draws is 289 watts (per nVidia site) ..... two of them - 578 watts.....If he hasn't SLI'd two of them then this is all moot. Personally, having a 295 upstairs, I would never SLI them as the performance boost is rather marginal.
Now add a CPU from that time (Intel 920 = 130 watts), cupla RAM modules, motherboard, optical drive, HD, SSD, fans, SSD, HD, account for capacitor aging and tell me what you get ...and then overclock it.
Extreme site is down so......Using this
http://www.psucalc.tk/#calcpsu
That PSU calculator gives
849 watts as the recommended PSU size.....with no overclocking whatsoever ! With both CPU (4.0 Ghz, 1.375 volts) and GPU's overclocked (.68 and 1.2) and ya pass
975 watts
Stock Intel 920
2 GTX 295
Generic MoBo
3 Sticks RAM
1 Caviar Black
1 Generic DVD
4 100mA USB devices
0 500mA USB devices
1 1200 rpm 0.12 amp CPU fan
4 1200 rpm 0.42 amp case fans
I'd expect the actual PSU output to be in the neighborhood of 650 - 700 watts (800w "at the wall") under normal gaming loads w/o overclocking. That
does not mean because ya have a label that says 750 watts, "it's OK".
1. Capacitor Aging - Even at the best quality units suffer from this effect as the machine ages.....using the minimum 10% allocation for the very best ones, that takes a 750 water down to 675 watts....personally 650 watt draw on 675 capable unit is too close for my comfort....and that's a best case scenario, something I'd expect out of a Corsair HX series. If it's a TX750, I'd use more than 10%.
2. Voltage Stability - The closer a PSU gets to a rated load, the more difficult it is to maintain stable voltages. I'd be real anxious to see what the voltage each rail is when under max load.
3. Ripple - A 700 watt load doesn't mean a PC will run reliably on a 750 watt PSU. Some models go out of spec at only a fraction of their load and lead to problems as was described by the OP. Note the quote here for example".
Quote:
For example the OCZ gamexstream 1010w has out of spec voltage ripple past around 50% load, so may not run systems reliably even though this psu calculator may indicate it could as HardOCP found out, whereas the OCZ proxstream 1000w in the same review was excellent even at 100% load.
