Magnetic fillters for unused side panel fan slots.
Last response: in Components
October 19, 2012 4:37:43 PM
I was just wondering if placing fillters on unused fan slots for a side panel was gonna decrease the amount of dust that would get to my graphic card and the cooler of my CPU.
I'm gonna buy the Silverstone fillters for a Cooler Master Elite 371.
a b ) Power supply
October 19, 2012 4:41:58 PM
Putting dust filters on the case fans will decrease the amount of dust coming into the case, dust filters i think require fans to be mounted, you can try using blue-tac pr something to stick the filters on empty fan spaces.
October 19, 2012 4:45:27 PM
These are magnetic dust fillters, so I don't think they need a fan.
a b ) Power supply
October 19, 2012 4:49:21 PM
Right then, yes they would stop dust from coming inside the computer but you will have to clean them when they get clogged with dust so that airflow doesn't stop.
October 19, 2012 4:59:13 PM
I've been reading some reviews. A lot of people seem to use them for unused slots on their side panels, but it seems like they do restrict the airflow a bit (from the CPU and GPU fans).
Do you think this will be a big hit to temps? I will only have a stock rear exhaust fan and a SCYTHE S-FLEX SFF21E as intake.
a b ) Power supply
October 19, 2012 5:05:37 PM
No it won't hit temps by a big amount, maybe 1-3c depending on how much dust there is on the filters.
