So I'm thinking about building my first computer and I had a friend who built his help me a little. I'd use it mostly for gaming, watching/ recording videos/ t.v., and programming (i'm a Software Engineer major but don't know much about hardware). I put together parts on NewEgg and I would really appreciate some feedback about the parts I chose.
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147061
Motherboard/ CPU combo:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.956565
Power supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028
Graphics card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102908
Harddrive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136950
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
CD drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
Monitor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236117
I would need this computer to last me a while, so spending a little more on better parts isn't a huge issue. However, I do want to keep this below $1000 if possible. Thanks for the help.
Case:
Power supply:
Graphics card:
Harddrive:
RAM:
CD drive:
Monitor:
