Will this power supply work with my selected components
hey I am attempting to find out if I have the correct power supply.; I know I have enough watts but I don't know anything about the rest of the stuff like voltages and amps. I tried buying and then using the PSU calc at http://www.extreme.outervision.com/PSUEngine but I still have no idea. so here is my parts list can someone please tell me if the power supply I selected will support my computer. And please keep in mind I intend to eventually overclock, add 2 more RAM sticks, and add a second video card to crossfire as it become necessary.
Power supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
HDD http://www.newegg.com/Product/Product.aspx?Item=N82E16822136891
GPU http://www.newegg.com/Product/Product.aspx?Item=N82E16814125418
I intend to eventually crossfire this card with a second one
RAM http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
I intend to purchase two more memory sticks if it becomes necessary
MOBO http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
SSD http://www.newegg.com/Product/Product.aspx?Item=N82E16820227791
DVD Burner http://www.newegg.com/Product/Product.aspx?Item=N82E16827106333
CPU http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
I intend to overclock eventually
7 answers Last reply
More about will power supply work selected components
  1. i cant view your hdd and the power supply.
    for crossfire, i would get a 750w such as the tx750w v2 or the xfx 750w. if you plan on running a single card, get a seasonic m12II 520w
  2. I agree with Troll about 750 watts and this is a good one from seasonic for $159 - it is full modular and will support your 2 cards in the future. http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087 SeaSonic X750 Gold 750W ATX12V V2.3/EPS 12V V2.91 SLI Ready 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
  3. i wouldnt go all out and get a x series power supply as it does cost alot. if you need modularity, the xfx xxx 750w will be a good balance between efficency and modularity and price
    thank you very much. i dont know if you noticed but this psu has $40 off promo code so its both higher quality, better 80 plus rating and cheaper. I actually originally selected the seasonic x-series 650w but then I decided to buy a more expensive card and I did not realize there was a 750w version for cheaper then the 650w version lol
  5. http://www.realhardtechx.com/index_archivos/Page362.htm
    crossfiring two 7870's will require a 600 watt psu
  6. This psu is excellent for 7870 xfire and cpu + gpu oc. Brilliant setup.
New Build Power Supplies Components Systems Product
