Radeon hd 5670 in a 300w power supply?
I want to buy de sapphire radeon hd 5670 512 ddr5
i have a 300w psu
and here are the estadistics
ac input:100-127.220
300w max input
12v 14.0A
15 answers Last reply
More about radeon 5670 300w power supply
  1. Acording to the system requirements from the Saphire site it want a 500w psu to be in the computer , unfortunatly it doesn't give the amp requirement for that card. Your best option would be to find out what the amp requirement is for the card and that will tell you if it will work with your power supply.
    http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=915&pid=311&psn=&lid=1&leg=0#
  2. You have only 168watts on your 12v rail (12x14=168), so that might not be enough. As you need to run your system off it too. However the hd5670 is a low profile card, so it only can get 75watt from the PCIE slot, so thats good. What are CPU do you have?
    It says that requires a 500w power supply when you using crossfirex and crossfirex is when you use two videocards
    de geforce gt 240 consumes more watts than the radeon hd 5670 and in the nvidia official site says that the geforce gt 240 requires a 300w psu soo thats why i say that the videocard can work
  4. I have a cooler master 350W PSU.It says, 2x12 V rails,23A (13A & 10A)....It has a power connector for the Card too....Can it support Radeon HD 5670 without any issues...?
    My PC also have,
    AMD A6-3650 APU
    Asus f1a55-m le motherboard
    Corsair Vengeance 4GB DDR3 RAM
    500GB Hitachi Hard disk
    Sony DVD Writer
    Please help me.Thanks in advance.
    My PC also have,
    AMD A6-3650 APU
    Sony DVD Writer
    Hi Dani - u r cutting it awful close. If that CM psu is this one beware:
    Elite Power 350 Lousy efficiency. Does not have two +12volt rails as advertised. No Over Current Protection as advertised. No Over Power Protection as advertised. Hardware Secrets
    Tom
    Tom
    I think it's the Elite itself.... :( So,that means I can't add a 5670 to my system...?? :ouch: My Goodness...!!!! Freaking PSU...??
    Dani - doesn't mean you can't add the card, but it does mean you run a much higher risk
    than normal that the PSU can't handle the demand placed on it. Biggest concern I would have
    from the Hardware Secrets testing is not the lousy effeciency or multiple +12v rails(presuming the avail amps are on a single rail) it is:
    Tom
    Dani - I read some of the review - there is some good news;
    The PSU can deliver it's rated output which is importan,
    and that of all the low end PSU's CM offers this is the
    best one.
    Tom
    Tom
    best one.
    Tom
    Is it...? Oh Thank you my friend....Thank you very much for all those information you provided....And by the way,let me ask something.What is that fused Power cable supplied with the PSU for...? Does that provide extra protection...??
    Haven't seen what you're asking about, but it does seem like it's some form of protection.
    Tom
    Tom
    I have got a cable,along with my PSU.Here...I've got the thing on ebay: http://www.ebay.com/itm/Lot-I-SHENG-SP-62-Power-Cable-13A-10A-250V-IEC-S3-RVV-300-500V-250-440V-/200824082902
    Does this provide additional protection...?
    Hi Dani - That doesn't provide any protection, it is a power cord only.
    It just provides AC power to your PSU which converts it to useable
    power for your computer components.
    Tom
    My PC also have,
    AMD A6-3650 APU
    Sony DVD Writer
    That's way too close for comfort. I believe a 500+ watt psu is a good investment as good ones can be found for just a little over 50 dollars like this one:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151093
    Thanks for the reply dude.But I have just bought the PSU (Not even 2 months over)....So I won't be having an option to replace it....So,what I ask is,though not very much comfortable,can I run my PC without noticeable troubles...?
    Hi Dani - just to restate - the 5670 draws very little power and you can run it with your current
    CM PSU.
    Tom
    CM PSU.
    Tom
    Wooh...! Now that's what I wanted to hear from someone....Thanks for all your support and help friends....I'm really thankful to you....I was having not little ambiguity about this topic.Some even said my system may restart frequently due to insufficient power supply....Now I'm pretty much sure that my PC can handle a 5670.For that I really have to thank you guys,especially you, friend (Tom).... :D
Graphics Cards Power Supplies HD Radeon Graphics
