Hey everyone, I have been lurking around on these forums for a few weeks now and thought I should join in on the conversation.
I've been recently looking towards building a budget PC, and I feel like I have come up with a rig I like:
CPU: AMD Athlon II X3 450 Rana 3.2GHz Socket AM3 95W Triple-Core Desktop Processor ADX450WFGMBOX ($78)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103886
Motherboard+RAM Combo: ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard + AMD Performance Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AP34G1608U1K ($106.98)
Link: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.971512
Case+PSU: Rosewill R218-P-BK-450W MicroATX Mid Tower Computer Case, come with 1x 120mm Fan, 450W Power Supply ($50)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147082
GPU: ASUS EAH6670/DIS/1GD5 Radeon HD 6670 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready Video Card ($92.99)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814121442
Harddrive: Western Digital Caviar Blue WD3200AAKX 320GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive ($70)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136770
Optical Drive: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM ($17)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Operating System: Windows 7 Home Professional 64-bit ($100)
Keyboard: LITE-ON SK-1788/BS 2-Tone 104 Normal Keys PS/2 Wired Standard Keyboard ($8)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16823107120
Speakers: Logitech S120 2.3 Watts (RMS) 2.0 Speaker System - OEM ($13)
Link: http://www.newegg.com/Product/Product.aspx?Item=N82E16836121013
In total plus shipping it comes out to be: $535.90
Since this will be my first build, ever, I just wanted to get some reassurance that all these parts are compatible, and I want to make sure I am not missing anything important.
I'm open to making any changes that doesn't effect performance, but will reduce the price.
Any and all help is appreciated, thanks in advance!
