600watt tr2 enough to power an i7 2700k and GTX 570 factory oced?
Question in the title, so is it?
Would i foresee any down performance?
thank you very much.
7 answers Last reply
More about 600watt power 2700k factory oced
  1. Horrible power supply.
    Got anything else?
  2. hahaha, yes im planning to upgrade to 750 watt psu, is that better? also is my i7 down performing. I mean, it doesn't seem much betteer than my i5 2500K @ stock speed....in games such as team fortress two and borderland.
  3. Because hyperthreading doesn't do anything for those games.
    Hyperthreading will make a difference in multi-threaded applications like 3ds max, or sony vegas.
    You won't see any difference between an i5 and i7 in terms of gaming.
  4. hmmm, but would a psu make any difference. i mean my i5 was using about 90 watt of power, this new processor uses 125 watt.
  5. also you're right, looking @ the i5 and i7 benchmarks for gaming is almost nil.
    Talking like 1-2 fps in some games lol...wow.
    No.
    They use relatively the same amount of power.
    Though I would recommend getting a new one.
  7. The issue with the TR2 is quality. It's crap. Not a perfect list but it puts the TR2 in the right place.
    http://www.eggxpert.com/forums/thread/323050.aspx
    There is no need for a 750w power supply unless you run a high end dual card setup like 2 x GTX 670s.
    http://www.realhardtechx.com/index_archivos/Page362.htm
    Components only draw as much power as they need. Getting a larger power supply than necessary gives you not 1/100th of 1 percent more performance.
CPUs Gtx Performance Intel i7 Power
