Need help!
Case: COOLER MASTER HAF XM
CPU: intel i7 3770k or i7 2700k
GPU: ASUS GEFORCE GTX 670 DCUII TOP- 2 GO sli
Power Supply: COOLER MASTER SILENT PRO GOLD - 800W
Hard Drive: 2x WD CAVIAR BLACK SATA III 6 GB/S - 1 TO - 64 MO (for Raid0 mod) + FORCE SERIES GT - 120 GO
RAM: PC G.SKILL KIT EXTREME3 2 X 4 GO PC15000 SNIPER CAS 9 1866 Mhz
Mothe Board: asrock z77 extreme 6 + buy Wifi
Fan CPU: Kuhler H20 620 +1fan
Monitor: ?
my budget is 2300$-2500$ (the less the better),and the PC is for gaming and editing gameplay! :bounce:
3 answers Last reply
More about need help
  1. Here you go:
    Case: NZXT Switch 810 - $169.99
    PSU: PC Power & Cooling Silencer MKII 750W - $109.99
    Motherboard: Gigabyte GA-Z77X-D3H - $144.99
    CPU: 3.4GHz Intel Core i5-3570K - $249.99
    Cooler: Noctua NH-D14 - $87.99
    RAM: 8GB Mushkin Enhanced Blackline 1600MHz 1.5V - $56.99
    SSD: 128GB OCZ Vertex 4 - $129.99
    HD: 2TB Samsung Ecogreen F4 - $129.99
    Optical: Lite On Bulk DVD Burner - $17.99
    Video Card: EVGA Geforce GTX 670 - $399.99
    Total: $1497.89
    Add a second GTX 670 to boost graphics power, and this gives you extra room for monitor/keyboard/mouse/OS.
  2. Consider an i7-3770K if you will be editing much. Otherwise, go with that i5-3570K. These two CPUs will perform equal in the games themselves, but the i7-3770K will give you an edge in the video editing.
New Build Cooler Master Intel i7 Systems Product
