Will this power two 2gb 6950's
I have a xfx pro 650 watt bronze psu. Will it be enough to power two 6950s and an i5 3570k
If you can get back to me asap because my budgets getting low now since i bought everything else
And my other build has that psu, so i thought i could save some cash.
5 answers Last reply
More about will power 6950
  1. It's not solely based on watts, but the psu looks decent enough to support it. I would go to pcpartlist and check the wattage, but you could try one, and see.
  2. should be able to although it depends on what other things you have installed hardware wise.
    Would be - 4 sticks of ddr3 ram -16gb
    Two 2 gb sapphire toxic 6950's
    1 normal dvd cd rw drive
    1 tb hdd
    I7 3770k cpu
  4. I say you now have a i7?
    By my calulations your system should never need much more then 3/4 of your PSU output.
    yeah i was going to go for the i7 but have opted out for the i5 3570k im just going for the aerocool strike x gold 1100 watt. its not too bad for the price plus it will have plenty of power if i want to upgrade. Thanks for the info mate
Power Supplies Power Intel i5 Components
