Solved
A very weird problem with my desktop
I have a Dell Inspiron 530s. It has this weird thing that it does, It was broken because it would not power up. So I decided to test the PSU and it worked, only with certain things. My DVD drive was one and the PSU fan also worked and the Harddrive when I tested my PSU with a paperclip and the green and black ground wires. But, after taking it out and I plugged it back in the 24 pin connector, the fans work but not the DVD drive. Here is a video of me showing you. Suggestions on how to fix this would be great.
Link: http://www.youtube.com/watch?v=bo8umNafiXk&feature=youtu.be EDIT: I found out that the fans only work if the VGA Cable is plugged in to another computer.
6 answers Last reply Best Answer
More about weird problem desktop
  1. Best answer
    I believe your problem is the power supply itself, I bet its an old power supply or its just a really bad one. Either way if its an old power supply then the reason would be the capacitors aging so the power supply loses its initial wattage and right now its unable to power on all the devices. Or if its a new power supply then there is not enough watts on it to support your computer.
  2. I will try that, do you think you can you find a link to a power supply suitable for this desktop. My current wattage is 250.
  3. I will reccomend you go for 300 watt and over just incase for future upgrade and that as the capacitators age you will still be able to have enough watts .
    Is your computer this: http://www.dell.com/us/p/inspiron-530s/pd
    I think you may have a bit of a problem finding power supplies for that as I believe it uses TFX12v form factor. Verify that the power supply in the link has the same screw slot and is identical. Your power supply factor is quite expensive compared to the normal ATX format.
    I believe this would be a suitable replacement:
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16817151090&name=Power-Supplies
    Edit: if you are unsure about that power supply, here is a guaranteed fit:
    http://www.ebay.ca/itm/Dell-Inspiron-530S-Power-Supply-300W-80-Replacement-/270745842342
    If you live in the states simply change the domain from ca to com
  4. Yes, that is my desktop. Thank you so much for your help and I will order one now.
  5. No problem, if I helped you out I would appreciate if you could select a best answer.
    All the best,
    Socialfox
  6. Best answer selected by TheComputerNerd.
Power Supplies Components
