Hey I recently bought a Sapphire HD 6450 and I installed the drivers off the disk and everything worked fine and could change my clock speeds and see my GPU temperatures. I just installed all the new drivers and Catalyst from the AMD site using the scroll down menus to my series of GPU. I restarted my computer after the installation was completed and my drivers seem to be working fine but when I opened catalyst it said it's unable to detect my hardware, has anybody got any ideas what could be the cause? I would really like to keep an eye on the temps as it's passively cooled and has got upto 80c playing world of tanks at 700mhz. maby a 3rd party GPU temp monitor recommendation? although I'd much rather have Cata since you get a few overclocking options.
Upgraded catalyst from "05/11?" (I think) to 03/12.
I upgraded from an ATI 2400 HD pro
My specs are:
PSU: 250 Watt
CPU: Intel Core 2 Duo E6700 @ 2.66
Mobo: Acer F671CR (Retail "SA90"
OS: Vista home premium 32 bit
Thanks in advance!
My specs are:
PSU: 250 Watt
Thanks in advance!
