Im almost done making a computer build. So far ive picked these for sure.
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130664
DVD-Rom: http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031
Power: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151093
Hard Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
CPU: I really want http://www.newegg.com/Product/Product.aspx?Item=N82E16819103960 but dont know if im better off going with http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996 being $100 cheaper
The motherboard and ram i cant figure out which is better
MB: http://www.newegg.com/Product/Product.aspx?Item=13-138-341&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=5&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=6#scrollFullInfo VS. http://www.newegg.com/Product/Product.aspx?Item=13-138-341&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=5&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=6#scrollFullInfo
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231405 VS. http://www.newegg.com/Product/Product.aspx?Item=N82E16820231429 being only $10 more
I also dont know what case to get. http://www.newegg.com/Product/Product.aspx?Item=N82E16811146080 VS. http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
So first off. Is this all compatible, that is the main thing i want to know. If you can tell me which items are better or even suggest other items, that would be awesome too.
