Solved
Which power supply should I buy
Please recommend me a power supply which will work well with the following configuration:
Intel core i3-2120 3.30 GHz
4 GB DDR3 RAM
LG DVD Writer
Gigabyte B75M-D3H Motherboard
500 GB Western Digital Hard Disk SATA 6.0 Gbps
No graphics card
4 answers Last reply Best Answer
More about which power supply
  1. Best answer
    What kind of case? Standard ATX? Micro ATX?
    Assuming it's a standard ATX case, you can get away with something in the 400-500 watt range:
    CORSAIR Builder Series CX430 V2 (CMPSU-430CXV2) $25.00 AR
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026&name=Power-Supplies
    Micro ATX
  3. Best answer selected by vorenor.
    Thanks a lot
Power Supplies Components Product
