Approximate Purchase Date: 1-2 weeks
Budget Range: ~800
System Usage from Most to Least Important: Gaming, Watching movies, internet
Parts Not Required: keyboard, mouse, OS
Preferred Website: Amazon.com
Country: US
Parts Preferences: none
Overclocking: maybe
SLI or Crossfire: maybe in the coming months but not now
Monitor Resolution: 1920x1080 would be great
Additional Comments: Now the problem here is with the CPU and MOBO.. I want my PC to be running a GTX 570 without any problems.. Since the mobo of my choice doesnt have any PCIe 2.0 slots will the GTX 570 work on the ASRock extreme3 gen3 without any problems?? Also if it does, will I be better off buying an i5-2500K or i5-3570K?? Those are the two main problems with me.. Need some answers on that ASAP, thanks.
Here is my current build order: (Please criticize or suggest if you think anything is wrong)
CPU : i5-3570k or i5-2500k (whichever one works better with my build)
MOBO: ASRock extreme3 gen3 or ASRock pro3 gen3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157279
RAM: Any 8GB DDR3 RAM (please suggest some)
CASE: CM Storm Scout
http://www.amazon.com/Cooler-Master-Storm-Scout-SGC-2000-KKN1-GP/dp/B00243HHNY
HDD: Any affordable 1TB HDD (please suggest some)
PSU: Any affordable ~750 Watt PSU or lower if possible. (suggest plz)
GPU: EVGA GTX 570
http://www.amazon.com/gp/offer-listing/B004EHZD5W/ref=sr_1_1_olp?s=electronics&ie=UTF8&qid=1340155734&sr=1-1&keywords=gtx+570&condition=new
I would also want to do liquid cooling so suggest some cheap ones too :b
So my main problem is with the MOBO and CPU, if i go with 2500k and ASRock extreme3 will GTX 570 work with these parts?? If not could you suggest something that will go with this build which is not very pricey??
Thanks Alot! Please reply fast
EDIT: I found a link to NCIX and they are running a deal for $219.99 for i5-3570K which is the same price as i5-2500k on amazon.. It ends in 24hrs I really wanna buy it but is it better or not??
Thanks again
Budget Range: ~800
Country: US
Overclocking: maybe
or
GPU: EVGA GTX 570
Thanks again
