Hi! my cpu configuration is below--
amd athlon x2 260 3.2 ghz proceesor
4gb starlite ddr3 1333 ram
gigabyte 78lmts2p motherboard
iball lpe223-400 smps
lg l1515s tft monitor
as suggested by the other members ,i bought the 6670 1gb ddr5 today!
but i have some questions--
1.windows 7 rates the card as 7.1 whereas others told that it shows 7.5!why is it?
2.i was installing a game.. i entered the 2nd dvd..suddenly the screen went blue,it had many things written on it..at lower side it was written physical dump memory!what happened??
3.in dxdiag,my video memory is being shown 2043mb..why is it??
4.when i had no gpu, i can increase my resolution to upto 1280*768..but after installing the gpu,i can not increase my resolution..it is fixed at 1024*768..at higher resolution ,it is showing 'out of range'!!what is the cause??
pleasee help..
pleasee help..
