Are all these parts compatible?
HDD: Western Digital Caviar Blue WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
RAM: G.SKILL NS 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-4GBNS
GPU: ASUS EAH6670/DIS/1GD5 Radeon HD 6670 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready Video Card
Optical Drive: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
CPU: AMD Athlon II X3 450 Rana 3.2GHz Socket AM3 95W Triple-Core Desktop Processor ADX450WFGMBOX
Case: COOLER MASTER Elite 311 RC-311B-BWN1 Blue Steel / Plastic ATX Mid Tower Computer Case
PSU: COOLER MASTER eXtreme Power Plus RS500-PCARD3-US 500W ATX12V v2.3 Power Supply
Motherboard: ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Just wondering if these parts are all compatible. Thanks in advance.
9 answers Last reply
More about parts compatible
  1. they should all be compatible
  2. Yes your good to go all is compatible P.S.I wouldn't buy that PSU it's not good cooler master makes great products but PSU ain't one of them .also that case has horrible cable management options :(
  3. Yes, sure! As compatible as wet socks and wooden boots! :)
    Corsair makes great modular power supplys
    Was not saying they don't was saying cooler master doesn't try reading what i wrote ;)BTW corsair doesn't make any PSU :lol:
  6. the Cooler Master EP PSu's are one of the many reasons CM gets such a horrible rep for PSU's. They're overrated, mislabled, and overpriced piece of turds that are barely better than generic PSU's that blow up all the time.
    Get at least Corsair CXV2 units or Antec EA / Neo Eco units or hell even OCZ psu's at the minimum.
    P.S. Corsair does not 'make' any units but buys them from manufacturers such as seasonic, cwt, flextronics etc which makes them to specifications that corsair or other companies demand.
  7. +1 lilotimz is telling you right and it's rock solid advice
  8. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
    ^^ He's right go for what I'm gonna get, if the PSU goes, your whole PC goes with it, so make sure you get a good n, you should be able to get that psu with less watts if you want.
    PSU: Corsair TX 650 V2 650w £75
    http://www.dabs.com/products/corsa [...] 0v2&src=16
New Build Systems
