Thermal Paste or Additional Fans/Cooling for this new Build
Hey,
I am concerned about the cooling of my a system I am about to build. It is a system primarily used for games, but I will not be over-clocking.
The parts I ordered are:
OS: Microsoft Windows 7 Home Premium ($149)
Optical: Lite-On LightScribe 24X SATA DVD+/-RW Dual Layer Drive IHAS424-98 - Retail (Black): $24.99
MOBO: Gigabyte Intel H77 LGA 1155 AMD CrossFireX DVI/HDMI Dual UEFI BIOS ATX Motherboard GA-H77-DS3H $99.99
CPU: Intel Core i5 3450 Processor 3.1 4 BX80637I53450 ($189.99)
GPU: Sapphire Radeon HD 7870 GHZ OC 2 GB DDR5 HDMI/DVI-I/Dual Mini DP PCI-Express Graphics Card 11199-03-20G ($349.99 $20 rebate not accounted for)
RAM: Corsair Vengeance Blue 8 GB (2X4 GB) PC3-12800 1600mHz DDR3 240-Pin SDRAM Dual Channel Memory Kit CMZ8GX3M2A1600C9B ($46.74)
PSU: Corsair Enthusiast Series 650-Watt 80 Plus Bronze Certified Power Supply Compatible with Intel Core i3, i5, i7 and AMD platforms - CMPSU-650TXV2 ($80.99)
HDD: Samsung Desktop Class Spinpoint F3 1 TB SATA 3.0 Gb-s 32 MB Cache 3.5-Inch Internal Bare-OEM Drives, HD103SJ ($109.00)
Case: Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case ($51.00)
So, my question is do I need Thermal Paste and/or more Cooling/fans?
3 answers Last reply
More about thermal paste additional fans cooling build
  1. that cheap glob that intel puts on its heatsinks will be fine for not overclocking.
    i hope your not in the US otherwise your prices are a bit high on some items. dont be shy to check out newegg.com also if you have a microcenter around, they have ivy bridge processors for cheap. and often motherboards too.
  2. I am a believer in adding more fans to pretty much any case to improve cooling. Although if you are not going to be overclocking, then adding extra cooling is not a necessity. The thermal paste that comes with the stock CPU cooler will suffice.
  3. I am in the States, California to be exact.
    On some of the parts, the prices were a little higher (on amazon) than New Egg, but as a prime member not having added tax and the free 2 day shipping made it a lot more beneficial. However. all of the prices were at least somewhat comparable to New Egg/Tiger direct prices. I can still return any of these if you know of any steals ;)
New Build Systems
