Power Supply, Overheating, and Motherboard questions
Hello I am a hardware newbie and I am looking to buy a power supply for my computer. I have heard that it is important to choose a quality power supply so I am asking for help. I already purchased a new video card (a Geforce 660ti) and it requires at least a 450 watt power supply with a minimum of 24 amps on the +12 volt rail, and two 6-pin PCI Express power connectors or four available hard disk power connectors. I would like to spend around 60 dollars or less if this is reasonable, but I am willing to go higher if necessary. Any suggestions? Also, I am worried that because I do not have any advanced cooling system in my case that my computer might overheat. Should I be worried about this, or will the fans be able to take care of it? Also I do not understand how a motherboard could limit my upgrading capability, will my motherboard cause me problems? My system specs are thus:
CPU: Intel i5 2320
Motherboard: Gateway, Model Number: IPISB-VR
Video Card (not installed yet): EVGA Geforce 660ti, Product Number: 02G-P4-3660-KR
RAM: 8Gb DDR3
Thank you,
-Geo
4 answers Last reply
More about power supply overheating motherboard questions
  1. The newegg gods aren't posting my links correctly. Checkout the corsair builders series 500w for $49.99 after rebate.
    Your system should run within specs since you're not overclocking. Noise is one of my concerns; not just temps. Normal temps for the cpu can go as high as 72C under load. Your video card will be the source of most of the noise, but that's normal. Only limitation of your oem motherboard is that it won't allow for any overclocking, but you can't do much about that since your operating system is tied to a small bios string (changing boards requires a new windows coa).
  2. get this power supply instead of the corsair cx series. more efficient and just built better
    http://us.ncix.com/products/?sku=59615&promoid=1295
  3. Thanks for the help, I went with the XFX 550w.
    -Geo
  4. no problem
Power Supplies Motherboards Components
