K Kyles503 Honorable Jun 18, 2012 123 0 10,690 Jun 21, 2012 #1 Can someone find me a case on Newegg that comes with a psu?
TheBigTroll Illustrious Apr 15, 2012 14,099 1 42,965 Jun 21, 2012 #2 well heres a pretty sweet combo deal http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.976644 Upvote 0 Downvote
TheBigTroll Illustrious Apr 15, 2012 14,099 1 42,965 Jun 21, 2012 #3 it has a very good power supply but i am not sure if it is enough for you. it will power any single card system though Upvote 0 Downvote
K Kyles503 Honorable Jun 18, 2012 123 0 10,690 Jun 21, 2012 #4 Any other ones a bit cheaper? Upvote 0 Downvote
K Kyles503 Honorable Jun 18, 2012 123 0 10,690 Jun 21, 2012 #5 Never mind, found one Upvote 0 Downvote
K Kyles503 Honorable Jun 18, 2012 123 0 10,690 Jun 21, 2012 #6 http://www.newegg.com/Product/Product.aspx?Item=N82E16811208041 Good if you ask me Upvote 0 Downvote
TheBigTroll Illustrious Apr 15, 2012 14,099 1 42,965 Jun 21, 2012 #7 i dont think that is a reliable choice. i have never heard of xion so that means its probably a no name brand. i wouldnt recommend it just because of the no name power supply Upvote 0 Downvote
