Hi,
i bought 25 mtr of CAT-5e Digilink cable. after crimping when connected to one end at pc and one end at router, the network icon in the taskbar of pc shows no connectivity. i tested with network cable tester and that shows the connection is ok. what is the problem. i though there was problem with RJ45 jack and then i again crimp two RJ45 jack at the both ends. suddenly, the network connection shows connected, but there is limited connectivity. i found in the status page that data were sent but there is no data received yet. what is the problem. i cannot access broadband. what is the solution. what is my fault ?
thanks in advance
Regards,
Kaushik
thanks in advance
Regards,
Kaushik
