Hi,
I bought an Antec 900 which has 2 front, 1 rear and 1 top fan. Does it matter which chassis fan connector on the mobo (ASRock Extreme4) I run each case fan too? Does the mobo throttle speeds thinking it's a certain fan at each spot?
Also, I ordered and Enermax TB for the side window port. Do you think it should it blow into or exhaust from the case?
thank you
thank you
