Hello all. Thank you in advance for your help.
I'm looking to have a computer built from CyberPower or iBuyPower. The budget is about $1,600 top end. I'm looking for something that can handle high game settings while streaming/recording.
I know that I can save money by purchasing the components and building the machine myself. I prefer a prebuilt for a few reasons, but the 3 year warranty/tech support is the biggest.
Anyway, here is the build I'm looking at so far. I have a couple of concerns/questions:
Wireless card? Depending on what room this goes in I won't have a wired connection.
Video card suggestions/changes? I've looked around and read suggestions to just install a video card myself because they're overcharging. I've honestly no idea how to do this//difficulty level. For a less than novice would this be advisable? I'm not
Motherboard suggestions/changes?
Will the options I've selected make heat a nonissue? I'm going to look in to overclocking, I've never done it before and don't know if I want to pay them for something I might be able to figure out on my own (unless it's suggested).
I haven't heard anything about the "smart response technology", any advice?
Anything obvious I'm overlooking/should fix would be appreciated. Thanks!
Build
The total price is $1,509 at CyberPower
I've customized a similar machine at iBuyPower for $1,428. They don't seem to have the same cooling options though.
My last option would be a machine built by the company that built my fiance's machine, which would look something like this:
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=110901978765#ht_5268wt_985
No video card is selected yet. Advice from their options?
Sorry for the huge post. Thank's again for your help.
Build
Case: Thermaltake Level 10GTS Mid Tower Gaming Case w/ EasySwap HDD bays, 2x Front USB 3.0 Ports, & Headset Holder [+38] (White Color)
Internal USB Extension Module: None
Extra Case Fan Upgrade: Default case fans
CPU: Intel® Core™ i5-3570K 3.40 GHz 6MB Intel Smart Cache LGA1155 (All Venom OC Certified) [+34]
Cooling Fan: Corsair Hydro Series H60 High Performance Liquid Cooling System 120MM Radiator & Fan (Dual Standard 120MM Fans (Push-Pull) [+9])
Motherboard: * [CrossFireX] ASUS P8Z77-V LX Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Lucid Virtu MVP, 7.1 HD Audio, GbLAN, 2x PCIe x16 (1 Gen3, 1 Gen2), 2x PCIe x1 & 3 PCI (Extreme OC Certified) [+6]
Intel Smart Response Technology for Z77: None
Memory: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory [+19] (Corsair XMS with Heat Spreader)
Video Card: NVIDIA GeForce GTX 670 4GB 16X PCIe 3.0 Video Card [+518] (EVGA Superclocked)
Power Supply Upgrade: 850 Watts - Raidmax RX-850AE 80 Plus Gold Power Supply [+95]
Hard Drive: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD [+25] (Single Drive)
External Hard Drive (USB3.0/2.0/eSATA): None
Optical Drive: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
Sound: HIGH DEFINITION ON-BOARD 7.1 AUDIO
Network: Onboard Gigabit LAN Network
Wireless 802.11B/G Network Card: None
External Wireless Network Card: None
Wireless 802.11 B/G/N Access Point: None
Internal USB Port: Built-in USB 2.0 Ports
Case 1 x NZXT Vulcan Gaming Case-Black
Case Lighting 1 x Liquid Neon Thunder Pattern Light
i
Processor 1 x Intel® Core™ i5-3570K Processor (4x 3.40GHz/6MB L3 Cache)-Intel Core i5-3570K w/ Intel Performance Tuning Protection
Processor Cooling 1 x Certified CPU Fan and Heatsink-
Memory 1 x 8 GB [4 GB X2] DDR3-1600 Memory Module-G.Skill Ripjaws X
Video Card 1 x NVIDIA GeForce GTX 670 - 2GB - EVGA Superclocked - Core: 1046MHz-Single Card
Motherboard 1 x Gigabyte GA-Z77M-D3H -- 1x PCI-E 3.0 x16, Lucid Virtu Technology-
Power Supply 1 x-Free Upgrade to 750 Watt Corsair CMPSU-750TXV2 ($20 Savings)
Primary Hard Drive 1 x 2 TB HARD DRIVE -- 64M Cache, 7200rpm, 6.0Gb/s-Single Drive
Optical Drive 1 x 24X Dual Format/Double Layer DVD±R/±RW + CD-R/RW Drive-Black
Sound Card 1 x 3D Premium Surround Sound Onboard-
Network Card 1 x Onboard LAN Network (Gb or 10/100)-
Operating System 1 x Microsoft Windows 7 Home Premium + Office Starter 2010 (Includes basic versions of Word and Excel)-64-Bit
Warranty 1 x 3 Year Standard Warranty Service-
i
