Sign-in / Sign-up
CPU Overheating! Please Help!!
  • CPUs
  • Configuration
  • Temperature
Last response: in CPUs
October 26, 2012 12:33:52 AM
[Config]
AMD Phenom II x4 955
Biostar TA790GXE 128M
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM
My system (CPU) is getting overheated. 10 min into BIOS and my system shuts down.
Not even booting into OS.
I was in this BIOS screen looking at CPU Temperature.
BIOS - Hardware Health Configuration - H/W Health Function [Enabled]
(7:43PM)
CPU Temperature : 36degC/96degF
SYS Temperature : 23degC/73degF
(7:44PM)
CPU Temperature : 54degC/129degF
SYS Temperature : 24degC/75degF
(7:51PM)
CPU Temperature : 99degC/210degF
SYS Temperature : 28degC/82degF
(7:53PM)
CPU Temperature : 110degC/230degF
and then 117degC and gone!!
And..
CPU Vcore : 1.360V
Chip Voltage : 1.216V
CPU-NB Voltage : 1.168V
Can you please help me in fixing this issue.
More about : cpu overheating
a b à CPUs
October 26, 2012 1:15:00 AM
Have you tried reinstalling your heatsink?, Also might be a bit dusty in there as well if you haven't cleaned it in a while which could cause heat issues as well.
m
l
October 26, 2012 1:30:26 AM
Thanks for the reply!
Yes i have reinstalled the heatsink, and its clean. But its the same issue.
m
l
a c 78 à CPUs
October 26, 2012 1:50:59 AM
The fan on the CPU should speed up as the CPU gets hotter.
With those temps, a stock cooler should sound like a jet taking off.
If it doesn't, you may have a bad fan or bad fan header.
m
l
