Hello all,
I am looking for what you think the best computer case with a side window is, that also costs less than $100.
Cooling is very important to me so I would like lots of fans/mounts. I want the case to look simple. Similar to the Antec Eleven Hundred.
It will be used with an ATX motherboard. I also would like lots of options for cable management.
Requirements
<$100
Lots of Cooling
Simple design
Good cable management
Thanks
William
Requirements
<$100
Lots of Cooling
Simple design
Thanks
William
