Solved
First Build component selection help
Hi all. I have made some preliminary selections for a new build. If anyone would like to give a quick critique, I am looking to get this below the $1000 mark if possible. Where would you all decide to save? I would prefer to keep the SSD if possible.
New Build Components
6 answers Last reply Best Answer
More about first build component selection help
  1. You don't need the top of the line last gen ssd. You are paying over $130 more than you should on this ssd!
    Get this on instead. This is a newer ssd and will perform on par with the other one,and is half the price!
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2267400&CatId=5298
    Your mobo is also alot. Are you really gonna do 3 way sli in the future? You could shave off $50-$70 with a similar motherboard.
    Check out this ASUS one.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
    Other than that it looks pretty good:)
    Cheers!
  2. A 750 watt PSU for less than $70.00 is questionable in my book. I would recommend something from Corsair, Seasonic, Antec, Enermax or PCP&C. Also, Please go here & use it as a guide to ask for help:
    http://www.tomshardware.com/forum/261222-31-build-advice
    Answer the questions and we will be better able to help you pick the right components for what you want the PC to do.
  3. Best answer
    If you aren't married to tiger direct...
    core i5-3570k - $189.99
    http://www.microcenter.com/single_product_results.phtml?product_id=0388577
    Asus p8z77-v pro - $159.99 (when bundled with the i5)
    http://www.microcenter.com/single_product_results.phtml?product_id=0386887
    16GB of RAM (corsair CL9) - $119.99
    http://www.microcenter.com/single_product_results.phtml?product_id=0385182
    though 16GB seems a little overkill right now. You could also save about $40 by going with 4x4GB
    HAF912 - $59.99
    http://www.microcenter.com/single_product_results.phtml?product_id=0343331
    7850 - $269 - $20 rebate
    http://www.microcenter.com/single_product_results.phtml?product_id=0390289
    Hyper 212 Evo - $36
    http://www.microcenter.com/single_product_results.phtml?product_id=0373900
    I'm a huge fan of the CoolerMaster 212 series especially for the money. I've been running a Hyper 212 Plus for years now.
    Vertex 4 - $129
    http://www.microcenter.com/single_product_results.phtml?product_id=0387745
    Sandforce controllers never get as fast as when brand new after filling the drive and then doing a TRIM, whereas the new Everest 2 controllers do return to new in box speed after TRIM... But V4 does give up a little raw speed when new.
    Can't find the articles I read this in... sorry, I guess you'll just have to take my word for it. Or not, up to you.
    PC Power & Cooling PSU - $109 - $20 rebate
    http://www.microcenter.com/single_product_results.phtml?product_id=0337656
    hard to go wrong with PC P&C
    any $15 120mm fan...
    THis comes out to about $1090 less $40 in rebates.
    As noted above, you can shave off $70 by going with a Asrock Z77 Extreme 4 mobo, another $80 by going with 8GB of RAM. I already went with a cheaper but equally good CPU cooler. If you choose to save on those 2 components, you could also go to a 256GB Vertex 4 and stay right around $1000.
  4. Best answer selected by desertsession.
  5. Thanks all for the help. There were great suggestions all around and you got me to my stated goal of getting below $1000. This is my first build so I appreciate the insight. I apologize for not following the sticky when posting the question, hopefully you generally understood what I was looking to do.
Build Components New Build Systems Product
