Are these parts compatible
locke9342
241
hi this will be my first build and i have created a list of parts and i would like to know if they are compatible and if i can do sli in the future https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=19533125
NZXT Apollo Black SECC Steel Chassis ATX Mid Tower Computer Case
Item #: N82E16811146025
Return Policy: Standard Return Policy
-$30.00 Instant
$89.99
$59.99
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822136769
Protect Your Investment (expand for options)
Recover Your Data(expand for options)
-$10.00 Instant
$84.99
$74.99
RAIDMAX HYBRID 2 RX-730SS 730W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Power Supply, New Version with Build-in ...
Item #: N82E16817152036
-$20.00 Instant
$79.99
$59.99
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-16GBXL
Item #: N82E16820231486
Return Policy: Memory Standard Return Policy
$98.99
ASRock P67 EXTREME4 GEN3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813157265
-$20.00 Instant
$169.99
$149.99
Intel Core i5-3550 Ivy Bridge 3.3GHz (3.7GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 2500 BX80637I53550
Item #: N82E16819116505
Return Policy: CPU Replacement Only Return Policy
EVGA 01G-P3-1460-KR GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Item #: N82E16814130660
Return Policy: VGA Standard Return Policy
-$11.00 Combo
$30.00 Mail-in Rebate Card
$399.98
$388.98
Subtotal: $832.93
It... still isn't public.
Anyway, you should be getting a H77 board with your 3550.
As for the PSU, it's rated at what I believe is 48 amps on the 12 volt rail, which is actually roughly 600 watts, which is enough for SLI, though personally I don't like meddling with SLI when using a cheap PSU. This PSU is more well known, and delivers more actual power, though it is $20 more.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139020
Also, if you're going for a gaming build, don't get the 16GB of RAM now, 8GB is more than enough and if needed you can add more in the future.
Merueth
412
locke9342
241
when you say cooler do you mean aftermarket cooler or stock pc cooler
locke9342
241
i have a question about coolers. when you replace a stock cooler with the aftermarket cooler what do you do with the stock cooler? i might get one in the future in case i upgrade to a overclocking cpu and i really dont like throwing things away can i sell the cooler?
g-unit1111
Actually you're not supposed to throw it away because if you ever have to RMA your CPU - Intel will ask for the serial numbers off of it.
I would not worry too much about how RAM DIMMs look since they may end up getting in the way of aftermarket HSFs if you end up replacing the stock cooler with something else... and that something else would likely end up hiding the DIMMs anyhow.
My last three rebuilds of my system I haven't run into that problem - my current build I had my CPU fan resting on top of the first two DIMMs and if I need to replace them I have to remove the fan but that's not that big of a deal.
g-unit1111
Not true - like I said Intel asks for the serial numbers on the fans if you have to return a CPU. Also if you don't overclock you can use the stock fan as you won't need the extra power of an aftermarket fan.
InvalidError
The OP asked what to do with the stock HSF after he's upgraded to something else. At that point, he would clearly have no further need for the stock HSF in his current system, overclock or not.
As for Intel asking serial numbers, I'm sure there are ways to work around that unless Intel is really using that excuse to deny RMAs.
