Solved
What's the best headset I can get that can compliment my sound card?
So I'll bet getting this sound card soon. http://www.newegg.com/Product/Product.aspx?Item=N82E16829132052 My question is, what headset would best compliment this sound card? My budget is $120.
I was thinking of the Roccat Kave 5.1 Surround Headset http://www.newegg.com/Product/Product.aspx?Item=N82E16826436005 but I'm not sure if the 5.1 Surround thing would be beneficial.
Any other suggestions?
Thanks!
3 answers Last reply Best Answer
More about what headset compliment sound card
  1. ATH-AD700 one of the most highly recommended low priced "Audiophile" headphones. I have this pair http://www.amazon.com/Technica-ATH-AD700-Open-air-Audiophile-Headphones/dp/B000CMS0XU/ref=sr_1_1?ie=UTF8&qid=1351262929&sr=8-1&keywords=ATH-Ad700
    Not too happy about the color but so much cheaper then the rest. I just bought a zalman mic to go with it for gaming. Can't even feel these things on your head with the wings that hold them up.
    They are also known for having pretty good sound staging for fps games
    Edit: I also own a asus xonar DG card, sounds good.
    Also these are not made to supress outside sounds or suppress sounds coming from the headset itself. With the xonar DG I could max out the volume and use them like speakers in my room lol. Any gaming headset you look at are trash in comparison to a good pair of headphones w/o a mic.
  2. Best answer
  3. Best answer selected by solinvictus01.
Sound Cards Gaming Headsets Components Product
