Hey everyone. I am having a problem with my build and I am not sure what could be wrong. After a while of everything going smoothly my system has started showing a new problem. After using it for a while all the screens will go black and audio and what not will continue for about a minute then the system restarts and boots up fine. No blue screen nor error. The only other problem I have ever had was the GPU cords where pressing against the case and every once in a while the computer would lose image and I would need to physically restart it and I would get a blue screen error when turning it back on. This seems to be different and I already checked the cable is not pressing on anything.
My Rig:
Case: CM Storm Trooper
Mobo: Crosshair V
Prossessor: FX 8150
Cooler: HP80
RAM: 16gbs of AMD entertainment 1600Mhz
PSU: 1000w OCZ
GPU: Radeon HD 6950 Video Card - 2GB DD
HD/SDD: 120gb Corsair SSD for OS(w7 ultimate) and important things, 2tb HDD for everything else
Monitors: Three 23inch HP 2301 and 1 Phillips 33 inch TV
Thanks so much in advance if you have any idea what might be wrong!!
~NiteScar
My Rig:
Mobo: Crosshair V
Prossessor: FX 8150
Cooler: HP80
PSU: 1000w OCZ
~NiteScar
