Hi, guy i got a old sony vaio desktop, i was wondering if i can put EVGA 01G-P3-1556-KR GeForce GTX 550 Ti (Fermi) FPB 1GB 192-bit GDDR5 PCI Express 2.0 card in. i dont know what kind of motherboard it came with, but the model of the desktop is VGC-RB34G
Update:
so my system is intel pentium 4 3.20GHz
http://www.geeks.com/details.asp?invtid=D945GTPLKR-OEM&cat=MBB idk if this is the motherboard i have i googled the model and found this
and will http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.868257&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=r4kun6z1xpzl combo work/be ok if i install it?
Update:
