Hi all,
I recently purchased a 40" Sony Bravia TV that I have connected to my PC and my PS3, both by HDMI cables so that I can use my speakers to output sound from both devices. Until the other day, after I reset the CMOS on my PC, they worked fine. I could switch easily between both devices and got sound.
Now, apparently after the CMOS reset, I get sound from my PC and if I switch to my PS3, from that as well. The issue is that when I switch back to my PC I get no sound. In the "Sound Devices" setting on my PC it has defaulted to "Digital Audio HDMI" instead of "AMD Digital Audio HDMI" which is grayed out. The sound is obviously coming from the HDMI via my graphics card which is why the AMD options need to be active. It always used to be but like I said, since the CMOS reset it doesn't seem to work anymore after I go back to my PC from having used the PS3. I can fix it relatively easily by unplugging the HDMI cable from the back of the PC and plugging it back in but this is not ideal. I've checked settings on the TV and nothing has changed, and after I plug the HDMI cable back in to the PC, it immediately sets the default sound to AMD.
Any ideas why this is? Could it have anything to do with the CMOS reset or is that just a coincidence? Thanks for any help.
