Tom's Hardware > Forum > Windows XP > Configuration & Customize > East Asian language package installation - Problem with Wi..
Forum Windows XP : Configuration & Customize - East Asian language package installation - Problem with Wi..
Archived from groups: microsoft.public.windowsxp.customize (More info?)
After checking the checkbox "Install files for East Asian languages" under
the tab "Languages" in Control Panel > Regional and Language Options, the
install starts. After 20 minutes, the dialog says that it cant find a few
files, and will continue the installation. Again, the dialog will pop up
telling me that another file can not be found. This happens over a period of
an hour, maybe two. I require the East Asian language packages, but I can not
seem to install them. Any suggestions?
Sponsored Links
Insert your Windows XP installation CD in the CD drive,
then begin the process of installing East Asian Languages.
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Microsoft Newsgroups
Be Smart! Protect Your PC!
http://www.microsoft.com/athome/se [...] fault.mspx
Reply to Anonymous
Yeah, i know you use the Windows XP Installation CD, but I use it and what i
said happens.
Reply to inde
There are 803 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
