I wanted a new gaming desktop to play the latest games at 1920 by 1080 at max settings with 60fps. Also I want it to be able to easily up gradable for the next few years. I have now spent 100+ hours researching my parts and how to guides and such. I do not want to exceed $1500 dollars and would prefer to keep it around $1300. Here is my build at the moment. Please let me know if I my power supply is sufficient, if my motherboard is a good choice and if it is compatible. Also, if I could get some just overall feedback on my build, that would be awesome. And if it could be made cheaper without sacrificing performance, that would be great to know. I will be playing Skyrim, SC2, League of Legends, and Diablo 3.
CPU-Intel Core i5 3570K Processor 3.4 4 BX80637I53570K
Motherboard-ASUS LGA 1155 - Z68 - PCIe 3.0 and UEFI BIOS Intel Z68 ATX DDR3 2200 LGA 1155 Motherboards P8Z68-V PRO/GEN3
GPU-Sapphire Radeon HD 7970 OC 3GB DDR5 HDMI/DVI-I/Dual Mini DP PCI-Express Graphics Card 11197-01-40G
RAM-Corsair XMS3 16GB (4x 4GB) PC3-10666 1333MHz DDR3 Memory Kit for AMD and Intel Dual Channel Processors CMX16GX3M4A1333C9
HDD-Western Digital Caviar Black 1 TB SATA III 7200 RPM 64 MB Cache Internal Desktop Hard Drive Bulk/OEM - WD1002FAEX
Case-NZXT Guardian Black SECC Steel Chassis ATX Mid Tower Case 921RB-BL
DVD Drive-Lite-On LightScribe 24X SATA DVD+/-RW Dual Layer Drive IHAS424-98 - Retail (Black)
Power Supply-OCZ ModXStream Pro 700W Modular High Performance Power Supply compatible with Intel Sandy Bridge Core i3 i5 i7 and AMD Phenom
OS-Windows 7 Home Premium SP1 64bit (Full) System Builder DVD 1 Pack
