Hey everyone, my current computer is getting quite outdated so I've finally decided to spend around $700 to rehaul my system to something much better. I'm currently running a Phenom x4 3.6ghz, 4gigs ram, gtx560, 2 10kraptors, 600 watt modxstream pro in a CM centurion 5.I've been looking around on newegg and think I have narrowed the new parts down to the following.
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504 (3570k)
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231560 (16 gig gskill ares)
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442 (crucial m4 128gig)
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293 (asrock z77 extreme4)
Cpu cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 (CM 212 evo) I plan to overclock to atleast 4.2ghz.
I will primarily be using the computer for gaming and just wanted to check with some knowledgeable people to see if this is the best bang for my buck and that everything is compatible and my 600 watt can handle it before I order the parts this weekend. Thank you all and take care.
