These parts worth a shot?
So i have been contemplating about getting a pc for a few years now and now im finally going to get one.
The following is a list of parts i was thinking of getting for the build, let me know what you think if it is bad tell me! but if you like it feel free to tell me so! any recommendations would be greatly appreciated like the case for instance; it' s a good price but im worried that it's too good to be true. Anyway thanks!
Product Image
OCZ AGT3-25SAT3-60G​ Agility 3 60GB SATA III 2.5 inch SSD
Asus P8Z77-V LX Motherboard
OCZ OCZ600MXSP-UK ModXStream Pro 600W ATX Power Supply
CiT Vantage Midi Mesh Gaming Case
Western Digital Caviar Blue 500GB SATAIII 6Gb/s 16MB Cache 3.5 inch Internal Hard Drive OEM
Product Image
Gigabyte GeForce GTX670 Graphics Card(2GB GDDR5, PCI-E)
Intel 3rd Generation Core i7-3770K CPU
Corsair CMZ8GX3M2A1600C9 8GB 1600MHz CL9 DDR3 Vengeance Memory Two Module Kit :D
6 answers Last reply
More about these parts worth shot
  1. First thing, what are you going to do mostly on the computer?
    Gaming, video/image editing/compression or just web browsing?
  2. it will bef or gaming and probably using a low end editor for youtube vids
  3. Then the i5 3570K would be enough, saves you some money.
    The rest of the build is fine.
  4. thanks the only thing i was concerned about as the case as it is quite a cheap case.
  5. Case looks fine, seems to have a lot of good views on Amazon.
  6. Thanks for the reassurance at least i don't need to spend £70 on a haf one with pretty much the same features
Components
