I have spent a lot of time trying to look for the source of the problem, a lot of google searching, double checking all the settings that should be relevant, but not much luck so far..
When playing the mouse and keyboard gradually become less and less responsive. I have seen a number of threads on a number of forums dealing with lag or no response in game but not one that seems to be the same. It seems to happen in the more intense matches, bigger better blah, but has absolutely no correlation with fps or anything. If i put all the in game settings low as possible, i still get the problem, to the same degree as maxed out settings.
It is almost like the mouse and keyboard are stuggling to connect on and off (wireless) however even if i go as closer as logically possible it still happens. Out of game ( as i type now i sit 3 metres away (not 30cm) and it works fine. However if i play the game and it is particaully irresponsive if i shut down the game the issue does continue for 10 - 20 seconds after.
I cannot work it out, and its making playing fairly unplayable.
As i said i have double checked all the drivers and made sure to put the most logical settings in order to reduce any difficulties, i have added in some .cfg files ( as recommended across the www.) for fixing laggy inputs. But laggy don't seem to be the issue, i am not entirely sure it is bf3 specific or a system/component problem.
