okay guys i got you a question, i am very inexperienced with computers and this would be my first build. any ways i don't know if any of the parts i picked are compatible with each other, and i dont know if any of them are any good i kinda put them together by how many people bought them and some on what if heard in articles. all help is greatly appreciated. here is my list! ohh and i dont know if i need both the burner and the drive.PS this is supposed to be a gaming pc.
CASE:RAIDMAX Raptor ATX-823BR Black Steel / Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156279
MOTHERBOARD:ASRock Z68 Extreme3 Gen3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
GRAPHICS CARD:EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
POWER SUPPLY: OCZ ZT Series 650W Fully-Modular 80PLUS Bronze High Performance Power Supply compatible with Intel Sandy Bridge Core i3 i5 i7 and AMD Phenom
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341051
CPU:Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
MEMORY STICK THINGS:CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
DVD ROM THINGY:LITE-ON Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model iHDS118-04 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276
DVD BURNER: ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
SOUND CARD:ASUS XONAR_DG 5.1 Channels PCI Interface Xonar DG Sound Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020
well if this build isnt good for gaming i would appreciate someone putting a good build thats around 800-900 bucks thanks guys
