Closed
Air flow help
  • Power Supplies
  • Cases
  • Fan
  • Components
Last response: in Components
October 28, 2012 7:08:13 PM
It has a
1 x 120mm rear fan @ 1200rpm (included alredy in case)
2 x 120mm front fan (bought alredy)
1 x 120mm buttom fan (bought alredy)
1 x 140mm top fan (included alredy in case)
How should I have it set up :3
Pics would help alot
More about : air flow
a b ) Power supply
October 28, 2012 7:23:27 PM
I would say both front fans are set to be intakes, as well as the bottom fan should be an intake. The rear fan and top fan should be exhausts. With this you have positive pressure in your case which is by far I say the best (if not one of the best) setup based on your fans.
Score
October 28, 2012 8:19:06 PM
what about top fan
Score
Best solution
a b ) Power supply
October 28, 2012 8:19:10 PM
Top fan as I said should be as an exhaust fan since hot air rises.
- Socialfox :)
November 10, 2012 4:35:12 AM
Best answer selected by tonyantonio.
Score
