Solved
Need desperate help
Hi all I am currently building my first of and following this guide http://www.buildacomputerguide.com/connect-power-supply-to-motherboard.html. I got to the quick power test and nothing happens with my counter or monitor. This is my setup
8GB DDR3-1600 (PC3-12800) CL9 Dual Channel Desktop Memory Kit (Two 4GB Memory Modules) 1 $57.99 $57.99
Builder Series 500 Watt ATX 12V Power Supply 1 $62.99 $62.99 Core i5 3570K 3.4GHz LGA 1155 Processor 1 $189.99 $189.99
Windows 7 Home Premium SP1 64-bit OEM (PC) 1 $99.99 $99.9 Vortex 3620 ATX Mid Tower Computer Case 1 $39.99 $39.99
22X DVD±RW Burner with Dual Layer Support - OEM 1 $15.99 $15.99
Caviar Blue 500GB 7,200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive WD5000AAKX - OEM 1 $84.99 $84.9 I e2250swd 21.5" LED Monitor 1 $109.99 $109.99. Z77 Pro3 1155 ATX Intel Motherboad
In the last section where u connect ur power supply it says there might be a small connected along with the huge connecter? I am hoping that is my problem :$
6 answers Last reply Best Answer
More about need desperate help
  1. Best answer
    Are you talking about the 24-pin power connector and the 8-pin voltage connector? If you plug those into the appropriate places on your motherboard it should light up. If it doesn't - either there's something wrong with your PSU or your case headers aren't properly connected.
  2. I connected them both and nothing lights up no fans do anything it's like a rock doesn't do anything. What are your suggestions that I do?
  3. any other help??
    Is the PSU switch turned on in the back? If it is you might want to think about RMA'ing your PSU.
  5. On the 3rd time reconnecting all the cords and wires it started :D I'm now installing windows. I just wanted to say a big thank you to toms hardware forums I now am addicted to see people's new builds and hopefully now helping people out. Thank you guys once again
  6. Best answer selected by spicy_benie.
New Build Systems
